The measurement panel in Pan X is set to “Pixels”. I want measurements to be in inches or centimeters. It was easy to change this in Pan 6, but I don’t see a way to do it in Pan X. Pixels mean nothing to me when it comes to paper sizes for printing forms.
Supposedly there are 72 pixels per inch but I haven’t confirmed this in a printed object. On the screen this value will vary depending upon the resolution of your monitor.
In Panorama X it is really “points”, not “pixels”, though there are some places where labels still say “px”. There are 72 points in an inch. You will eventually be able to set measurements to inches or centimeters but it is not possible at this time.
Thanks. The conversion formula from points to Inches helps a lot. It would be great to be able to do it on the fly, of course.
Any progress on having inches and centimeters as options in “Measurements”?
