I hoped Panorama X would adapt to the system (number format) settings more than earlier versions did. But it seems to me that Panorama X internally is still using U.S. format instead of the system settings.
I am using a banking application and I every day am exporting data from that application as tab separated text files. Obviously Panorama X does not understand the decimal numbers in that file (with the system’s decimal delimiter, the comma here in Germany). It imports the values as integer numbers; the output pattern (#.,## €) of that field displays such a value as e.g. 141,00 € instead of 141,39 €.
I have to use an import formula that replaces the decimal comma with a decimal point.
When you type in a number it accepts it using your local format, right? I would have thought that import would have done the same thing, I will have to look into that. I have filed a bug report:
