We’ve always used the MATH tab to propogate within a column. No MATH tab on Panorama 6. How is the propagate function accomplished?
You have two choices:
- You can use the Vertical Data tabulation dialog in the Fields menu.
- You can use the preferences to switch the menus to “Classic” mode, which will give you the Math menu back.
FYI, in Panorama X the propagate function is found in the Morph submenu of the Field menu. It is back as a separate menu item like it was in Panorama 5.5 and earlier, instead of being part of a larger dialog.
If you go to the Panorama menu - Preferences - General Preferences and set Menu Option to “use classic menus”, everything should appear where you are used to it being.
Jeff Kozuch
President, Acacia Systems
Panorama Programming and Training
Apple Certified Technical Coordinator
Member, Apple Consultants Network
jk@acaciasystems.com
562-437-7690
Yay! Thanks!
