After creating a button in a form I want to create another object behind that button. Is this possible? Right now it seems that an object created after another object will always display in front. I want to change the graphic stacking order.
In graphics mode you select the object you want to reorder and then choose from the Object menu Arrange. You then can choose to move it up or move it down or move it to the back or to the front. Also be aware that you can select objects from behind other objects by command-clicking over the objects.
