Hello again Panorama friends,
You have been very helpful with by first request. It worked just fine. My remaining problem is getting two different results to give a total amount.
The first formula gives the correct total amount of 873,600 by using the multiplier of 10400 : {PATTERN(10400*(VAL(«TK»)+VAL(«K»)+VAL(«1»)+VAL(«2»)+VAL(«3»)+VAL(«4»)+VAL(«5»)),"#,.##")}
The second formula gives the correct total amount of 640,360 by using the multiplier of 11435: {PATTERN(11435*(VAL(«6»)+VAL(«7»)+VAL(«8»)),"#,.##")}
I want to display the total of the first formula plus the amount of the second formula such as $1,513,960
You need to realize that the first argument of the pattern( function as a number. In the first formula it is 10400*(VAL(«TK»)+VAL(«K»)+VAL(«1»)+VAL(«2»)+VAL(«3»)+VAL(«4»)+VAL(«5»)), in the second, it is 11435*(VAL(«6»)+VAL(«7»)+VAL(«8»)). Simply add those together, and plug the sum into the first argument of the pattern( function.
As Bruce says, you need to combine both formulas into a single pattern( function which can be a little hairy trying to keep track of all the parentheses involved. I think this might be what you need:
Thanks Gary. That worked just the way I wanted. I was try to add the two figures and it was a disaster. You are exactly correct trying to keep track of the right amount of parentheses. As always thanks for your help.
The parentheses around the two summands are redundant.
a*(b+c+d)+e*(f+g+h) works just fine. Multiplication comes first, and then addition. This is why you need the parentheses where they are: a*b+c+d only multiplies a times b, and then adds c and d, so you need the parentheses to add b+c+d first. e is multiplied time f+g+h because of the parentheses, but since multiplication comes before the addition, you do not need parentheses around the product. But it does not hurt to have them. a*(b+c+d)+e*(f+g+h)=(a*(b+c+d))+(e*(f+g+h))
That “strange markup” is called Markdown, it is by far the most widely used document markup language. According to Wikipedia, “Implementations of Markdown are available for over a dozen programming languages” and “Markdown plugins exist for every major blogging platform”.
Markdown is also used for all Panorama X documentation.
Markdown has special features for including source code in a document. Probably the easiest method is to simply indent the code by 4 spaces. When you do that, special characters like asterisks are not converted to formatting, but displayed as-is, like this.
3*4+5
You can also embed code or formulas by enclosing it in back-ticks, for example 3*4+5 or x*y^2. Without the backticks, this would display as: 34+5 or xy^2, not good, obviously.
Markdown is super easy and with about 5 minutes learning you’ll find it second nature. When I was looking for a discussion platform for Panorama X the fact that Discourse uses Markdown was a huge plus in my evaluation.
