Hello!
I am unable to use either the find/select or morph dialogs due to a consistent “Dialog program error — dialog will be aborted
.” error. This is causing the operation to fail consistently.
This is a fresh install of PanoramaX (latest version: 10.0.01 build 2685
). I have repeated the tests after completely uninstalling the application (including deletion of all caches, plists and other related files using CleanMyMac), and then reinstalling a fresh copy from http://provue.com.
This is a 2017 MacBook Pro (13" retina) with 3.5Ghz i7 and 16GB RAM. It is running the latest MacOS High Sierra (10.13.2) with all patches applied.
I have tried the tests with a very simple two field database, with just one sample record. A short screencast of the bug is in the Dropbox link Screencast of the PanoramaX bug , which describes the problem and the tests in more detail.
Can you help?
Thanks!
Anupam
