"Find and Replace" in Edit menu not supported?
“Find and Replace” is shown in Edit menu but gives an error as shown below. Is it no longer an option along with the similar command “Change”. Thanks!
That menu item is generated automatically by Apple. Eventually it will work, but for now, you can perform this function using the Morph Current Field dialog, with the Replace or Replace Word option.
