I just fixed a bug using regular expressions, and I wanted to briefly share what I did as I think it really illustrates the power of regular expressions.
The bug was that the sample checkbook data used in the tutorials didn’t import properly in regions that used non-US date and number formats. I know, ugly Americans, right?
The raw sample data looks like this:
01/01/«YY» 100 Sparkletts Office Supplies 14.20 32,827.78
01/03/«YY» 101 Blue Cross Payroll Health Insurance Group Xbg-872 975.00 31,852.78
01/04/«YY» 102 Valley Gas Utilities Heating 49.90 31,802.88
01/05/«YY» 103 AT&T Telecom Long Distance Phone Service 236.24 31,566.64
(The «YY» is automatically converted to the current year, so don’t worry about that.)
There are two problems – the data format is mm/dd/yy, but many countries use dd/mm/yy. Also, the money values use periods for decimal points, and commas for thousands separator. Again, doesn’t work in all countries.
Here is the new code I added. The sample text has already been loaded into a variable named * importPreviewRawData*
importPreviewRawData =
replace(
regexreplace(importPreviewRawData,
"\b([0-9]+)\.([0-9]+)\b","$1«DECIMAL_POINT»$2",
"\b([0-9]+)\,([0-9]+)\b","$1«THOUSANDS_SEPARATOR»$2"),
"«DECIMAL_POINT»",info("decimalseparator"),
"«THOUSANDS_SEPARATOR»",info("thousandsseparator"))
if info("defaultdatepattern")="DD/MM/YYYY"
"([0-9][0-9])/([0-9][0-9])/«YY»","$2/$1/«YY»")
This code uses the regexreplace(
function to convert the decimal points and thousand separators to the correct symbols, and rearrange the dates if necessary, By using regular expressions, I was able to do this in a general way, so if I later add other sample files they should work automatically.
Unfortunately I don’t really have time right now to explain the actual regular expression patterns I used, though they are really quite simple. And I’m not sure I really came up with the most elegant solution possible. But I just wanted to illustrate what sort of thing is possible. In Panorama 6, this would have been extremely difficult to do (not impossible, but very tedious). By using regular expressions, I was able to get it working in a few minutes.
