Was working on a routine where the IF info(“trigger”) CONTAINS “Dialog.Initialize”…
seemed like a perfect solution, but it didn’t work. In playing around with this further it appears this is never triggered, as illustrated in the attached simple database. Hitting the test button displays a dialog sheet that contains a text display object showing the contents of a variable. This variable is set to an initial value before the run dialog loop, and to a different value inside the loop’s IF info(“trigger”) CONTAINS “Dialog.Initialize”… block. The variable never get’s the inside the block assignment.
Can anyone see what I’m missing?
Demo here: https://u95490672.dl.dropboxusercontent.com/u/95490672/Dialog.Initialize%20Demo.pandb.zip
